sorry man i was mistaken. its an auto :( far out. But ive got it home and am stripping it today before i take it for scrap tmrw. So is their anything people want that isnt too hard to take off?
You can make a 'Auto Brake peddle" into a manual clutch peddle, I did it for my 2 door ages ago.
Like this.
Nigel
Thanks for the suggestion Nigel,
But my fabricating skills leave a lot to be desired. Plus wouldn't the brake pedal be larger if I'm using one from an Auto?, judging by the link Scott sent, the pedals from a manual car are both smaller. Are they easy to buy Scott? My Japanese is not good. Flauski, are you there??
Yes the bit you put your foot on is, but I just cut it up with a grinder, drilled a extra hole for the clutch cylinder push rod, and bent it a little with a 18inch shifter to get the placement off the peddles.
not very hard.
Nigel
