Differences between Transmission Crossmembers
spitz17
Apparently up to HLS30-46000 (L24) the rear engine mounting assembly was 11330-E4100 (up to 7/73) shown above on right for ALL transmissions, and from HLS30-46001 (L26) it was 11310-N3000 (from 8/73) shown above on left for manual only.
Either I'm not reading the above correctly - missing a period or comma somewhere - or something is wrong.
"up to HLS30-4600(L24)" - - that would be 70/71 Model Year 240Z's
"and from HLS30-46001 (L26)" - - NO - HLS30-46001 would be the start of the 72 Model Year and would have the L24
Yes - from 8/73 forward it would be an L26, but then that would be an RLS30
Also - I'm not sure what picture your looking at when you say "above right" or "above left"... the pictues in the original Post all show up one on top of the other. Are you looking at the last picture - that shows the two mounts together?
FWIW,
Carl
FWIW,
Carl
Okay let me see:
Jun 74 revision:
Section 19-2 Engine mounting (Auto All. Manual up to C/# HLS30-46000) (From RLS30, GRLS30) Part # 11330-E4100 assembly Up to 7/73; Part # 11310-N3000 assembly From 8/73
Section 19A-2 Engine mounting (Manual from C/# HLS30-46001 RLS30 GRLS30) Part # 11330-E8700 assembly L24 Manual Up to 6/72; Part # 11310-N3000 assembly From 7/72
Edited by bpilati
  • 4 years later...
Resurrecting an old topic but I am looking for a cross member discussed above that would be for a 70-71 Z (it's the one pictured above that would bolt to the trans tunnel vertically) .
Please contact if available (also posted a WTB classified).
Thanks
zKars, you are "The Man" when it comes to "giving up" your parts for club members..... you do over and over again.I'm proud to be on the back of Morton's car with you....Good job!    Guy
Edited by Diseazd
  • 4 years later...
Thanks
Ok, now I'm looking for one of these also.  Please let me know if you have one.
  • Who's Online   1 Member, 0 Anonymous, 719 Guests (See full list)
