February 3, 201213 yr comment_379669 A little off subject, but what is the trick to getting the lock cylinder out of the ignition? I tried for days before finally giving up..The proper way to remove these small retaining pins is to drill a small hole right next to it.Take a sharp edged tool like a punch , and gently pry the pin up .No destruction if you take care , and the pin is reusable .I know, reads easy enough, but doing this takes care - don't drill the hole too deep- maybe 4-5 mm .Good luck !PS It's best to have the whole assembly in a vise , don't attempt this while it's still in the column. Edited February 3, 201213 yr by Unkle Link to comment https://www.classiczcars.com/forums/topic/42011-lock-rebuilding-and-internal-parts-ignition-doors-hatch/?&page=2#findComment-379669 Share on other sites More sharing options...
February 4, 201213 yr comment_379721 Thanks for the info!!!! It'll give me something to work on this weekend Link to comment https://www.classiczcars.com/forums/topic/42011-lock-rebuilding-and-internal-parts-ignition-doors-hatch/?&page=2#findComment-379721 Share on other sites More sharing options...
