Posted January 21, 201213 yr comment_378290 I have a spare pair of SUs on a 240Z manifold. They appear to look correct except the name. They have both got the name 'SU Carburettors Birmingham England' on the top of the float bowls. Were other SUs made with the four stud mounting flange.? Are they 240Z carbs? Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/ Share on other sites More sharing options...
January 21, 201213 yr comment_378291 Jaguar SU's maybe? Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378291 Share on other sites More sharing options...
January 21, 201213 yr comment_378319 Olzed,Any pics or numbers, throat size? A lot of European cars in the 60's, 70's used SUs. Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378319 Share on other sites More sharing options...
January 21, 201213 yr comment_378323 I'm sure that when Bruce wakes up he'll chime in. SU's licensed their design out to different manufacturers. Hitachi was one (for Datsuns) and I know that Stromberg was another on European cars. The designs were slightly different but the principle was the same. Even within Hitachi SU's I have seen different castings on the throttle bodies. Most have letter stamped on them ("ISO" I think) and some do not.By your description it sounds like yours were actually manufactured by the SKinner's Union company. Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378323 Share on other sites More sharing options...
January 21, 201213 yr Author comment_378335 Yes, I'm thinking they are not correct for the 240. The area at the top of the dash pot where the little plunger goes is tapered.The same area on my 72 Hitachi round tops is straight.I thought there was something different with the setup. The linkage between the two has been altered slightly. Shortened I think.I'm guessing someone has replaced these for the flat tops.It will be interesting to see how they perform. They will be bolted to a stationary engine that idles on three cylinders, so as long as they are look good and run i'm happy.Pictures shortly. Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378335 Share on other sites More sharing options...
January 21, 201213 yr Author comment_378337 Carbs. 1 5/8 inch at the intake throat. Tags screwed to each float bowl reads. AUD 425 F---AUD 425R Edited January 21, 201213 yr by olzed Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378337 Share on other sites More sharing options...
January 21, 201213 yr comment_378349 Compared with my '72, the body of your tops look a little squashed, and the neck a little longer. Could just be the angle and/or my imagination. And, while it could be hidden, yours appears not to have a buttress of sorts on the neck.But also one heck of a lot shinier than mine.Chris Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378349 Share on other sites More sharing options...
January 21, 201213 yr Author comment_378361 Jetaway.The buttress on the neck vanished when I turned it off in my lathe, and they look shiny after a good polish, also in the lathe. The manifold and carbs were pretty cruddy, and I have been trying to spruce them up for a week. Soaked in everything I could think of, even coca cola for three days. I ended up with a lick of silver paint, dabbed on with a brush, and wiped it off. Does'nt work so well on the smooth casting, but on the rough stuff, its great. Brian. Edit the Coca Cola myth is a myth. I had a rusty nail soaking as well and nothing happened. Edited January 21, 201213 yr by olzed Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378361 Share on other sites More sharing options...
January 21, 201213 yr comment_378367 Jetaway.The buttress on the neck vanished when I turned it off in my lathe, and they look shiny after a good polish in the lathe. Well, they won't work now, I guess. Actually, that would explain the difference. Did you try Nevr-Dull before the paint? I went out and tested some on my manifold and it did make some progress. Chris Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378367 Share on other sites More sharing options...
January 22, 201213 yr Author comment_378380 Never heard of Nevr-Dull Chris. We are limlted to what we get here. I was thinking of an acid, but not sure which. I should have just drank the Coke.:stupid: Link to comment https://www.classiczcars.com/forums/topic/42018-su-carbs/#findComment-378380 Share on other sites More sharing options...
