Does any one have a picture of a door panel and the piece to the rear of it, (the piece that is clipped to the dog leg?) Ideally I would like to dee the two together without a seat in the car, but I'll take what I can get.
I'm going to repaint the panels 2 tone and I need to figure out where the boundaries should be for each color.
Also, any new ideas for the chrome strips in the door panels? One of the posts I read said to use a 3/8" adhesive strip from an auto parts store. I was only able to locate 1/4 ", which is not wide enough.
Thanks.
Edited by tlorber
https://www.classiczcars.com/forums/topic/42029-interior-pictures/
For the chrome strip, try a hobby store for Monokote adhesive trim in chrome silver.
Pic isn't exactl what you want, but might help. Bottom-line, the chrome strips line-up if everything is properly assembled.
I basically copied interior I did years ago in my previous Z.
Seats are custom. Vinyl side panels with upholstery cloth center inserts. The center fabric is a dark grey/light tweed. I "think" name of the fabric was "Opal". I can look it up in my records if you like.
Carpet is a charcoal loop I got from from Home Depot. Used old carpet as patterns and finished with sewn vinyl edging.
Thanks for the replies, guys. I will be doing a pattern similar to Julios but with a burgundy vinyl in the insets. Eventually I will install 300 ZX seats once they are painted 2 tone to match.
  • 4 weeks later...
I thought I'd post a follow up here. On a test panel, I tried 2 different silver rattle cans that I had at the shop. I also bought some chrome adhesive pinstriping, since I couldn't find any mylar at the hobby shop, and finally I bought some Duplicolor Instant Chrome.
The pinstriping was definitely the most chrome looking, but I couldn't get it to stick to the tight curve of the plastic bead, so I ended up using the Duplicolor. While it is by no means mistakeable for chrome (i.e you will not be spraying it on a flat surface and then using it for shaving in the morning) it has a much higher reflectivity than either of the silver paints. I would say it has 70%-80% of the reflection/brilliance of chrome.
The final door panel is shown below. Hope this helps someone else down the road.post-20299-1415081784258_thumb.jpg
I found some silver/aluminum duct sealing tape at Ace, applied and cut to size with an exacto knife.
Definitely not chrome, more of a polished aluminum look but it is consistent and doesn't look toooo shabby. Better than the chrome with blue gaps. So far has worn well, and the roll was about $5 with plenty left over in case a redo is necessary in the future.
I forgot to mention that I tried tape as well on the test panel. The problem I had with my tape is that the aluminum was so soft that when it got scraped (by fingernail) it left marks.
Edited by tlorber
