Posted January 22, 201213 yr comment_378414 I have a pair of Birmingham manufactured SUs on a 240 manifold. Their serial numbers are AUD 425F and AUD 425R.Any one know what they are origionally off. Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/ Share on other sites More sharing options...
January 22, 201213 yr comment_378430 I have been unable to find that model number in the SU book. Why do you ask? FWIW F & R stand for Front and Rear. Sorry I can't be of more help. Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/#findComment-378430 Share on other sites More sharing options...
January 22, 201213 yr comment_378433 Lookslike 1970 MGB had them.Somewhere to starthttp://www.austinmemories.com/page130/page131/page131.htmlhttp://www.sucarb.co.uk/ProductSearchResults.aspx?SearchTerm=AUD425 Edited January 22, 201213 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/#findComment-378433 Share on other sites More sharing options...
January 22, 201213 yr Author comment_378439 Bruce Palmer said: I have been unable to find that model number in the SU book. Why do you ask? FWIW F & R stand for Front and Rear. Sorry I can't be of more help.Thanks Bruce.I wondered why someone would bother putting these on a 240 manifold, unless it was a replacement for the flat tops.Some good information there Blue. When I am fully awake I will read it fully. Thanks.Brian. Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/#findComment-378439 Share on other sites More sharing options...
January 22, 201213 yr comment_378441 Not exactly what you want but close... with some good spring data at the front.http://www.tr-freun.de/triki/lib/exe/fetch.php?media=vergaser:su_butec_1969-1983.pdf Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/#findComment-378441 Share on other sites More sharing options...
January 22, 201213 yr comment_378454 These MGB may be an oddity at 1 3/4" and are HS6 an equivalent to the 46mm Hitachis. The Burlin book I have shows the 70s MGBs ran HS4s or 38mm carbs on the 1800. Right thru that series the SU numbers I see are all right in that range. I just don't see AUD 425..... Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/#findComment-378454 Share on other sites More sharing options...
January 23, 201213 yr comment_378457 Hi Bruce,here is where I found the MGB references: http://www.team.net/archive/mgs/2000-06/msg00861.htmlhttp://www.team.net/mharc/archives/html/spridgets/2001-03/msg00950.html Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/#findComment-378457 Share on other sites More sharing options...
January 23, 201213 yr Author comment_378470 Thanks Guys. Looks as though they are 1970 MGBThe link Austin memories is interesting Blue. Lots of good information. Link to comment https://www.classiczcars.com/forums/topic/42031-su-query/#findComment-378470 Share on other sites More sharing options...
