Posted January 25, 201213 yr comment_378709 I have a 77 280Z with factory engine an factory 5 speed manual I have replaced all fuel system, starter, fuses, fuel pump. An when you go to start it the parking light an taillights will come on an the volt guage an the car will backfire. Could it be a fusable link bad an if so were are they all located at on the car? I need to get the car running to sell it. Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/ Share on other sites More sharing options...
January 25, 201213 yr comment_378711 1cem said: An when you go to start it the parking light an taillights will come on an the volt guage an the car will backfire. What?? Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378711 Share on other sites More sharing options...
January 25, 201213 yr Author comment_378714 yea when you turn the key to try to start it the parking lights an the taillights an volt gauge will come on an nothing else an it backfires an it wont start Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378714 Share on other sites More sharing options...
January 25, 201213 yr comment_378719 The fusible links are under the hood. Download a copy of the FSM from the link below. Also get a copy of the wiring diagram from Blue's tech tips. I have a strong suspicion that there is a lot more going on than a bad fusible link. Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378719 Share on other sites More sharing options...
January 25, 201213 yr Author comment_378726 Hey Steve J what do you think is wrong with it what would be your guess on it? Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378726 Share on other sites More sharing options...
January 25, 201213 yr comment_378730 You haven't supplied enough data to speculate. Was anything like this happening before you made any repairs, such as any other electrical problems? What all did you replace with the fuel system? Did you connect the battery properly after replacing the starter? How long have you had the car? Did you or a previous owner attempt any electrical repairs?General problem descriptions tend to get general responses. Detailed descriptoins will yield better results. If the wiring hasn't been hacked, you may want to look for wire damage in the steering column, especially if anybody ever tried to hotwire the car. Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378730 Share on other sites More sharing options...
January 25, 201213 yr comment_378740 I would be leaning more towards fuel. Also curious if the motor had been re-built recently. As stated, you need to provide way more details. Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378740 Share on other sites More sharing options...
January 25, 201213 yr comment_378747 five&dime said: I would be leaning more towards fuel. Also curious if the motor had been re-built recently. As stated, you need to provide way more details. Considering the OP said the lights & voltmeter came on when he tried to start the car, I feel pretty confident that there are electrical issues at play as a primary or secondary issue. I'm curious about how he answers my questions back to him. Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378747 Share on other sites More sharing options...
January 25, 201213 yr Author comment_378755 replaced everything in the fuel system battery fuel pump starter alt fule injectors cleaned fuel rail out all new fuel lines an never had the car running since i bought it in aug. 2011. lady i bought it off of had it running an drove it to her house were it sat 2 months not started. an lady i bought it off who got it off a guy who owed her money an she was going to crush it an i bought it before it got crushed. already replaced some fuses in it an some fuseable links that were bad. I need the car gone ASAP I got its replacement sitting in the driveway a 1970 Mercury Cougar XR7 with 351 Cleveland. Edited January 25, 201213 yr by 1cem Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378755 Share on other sites More sharing options...
January 25, 201213 yr comment_378757 Ah ok . From my deciphering of the original post, I thought that all the electrical bits were working properly and both the volt meter and exhaust were backfiring Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378757 Share on other sites More sharing options...
January 26, 201213 yr Author comment_378800 so what might be wrong with this car? Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378800 Share on other sites More sharing options...
January 26, 201213 yr comment_378818 Bad flux capacitor?Did you do what Steve directed you to in his first post? Edited January 26, 201213 yr by LeonV Link to comment https://www.classiczcars.com/forums/topic/42061-not-getting-power-to-all-the-car/#findComment-378818 Share on other sites More sharing options...
