Posted January 28, 201213 yr comment_379032 I want to take apart the throttle linkage on my 73 240 to clean it up and replace the rubber firewall boot. The dumb question: Do those little ball and socket joints just pop apart? I tried to get them apart but they didn't yield to medium pressure. I didn't want to break anything so I thought I better ask before I tried to strong-arm them. Thanks, in advance, for your answers! Edited January 28, 201213 yr by jharvat Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/ Share on other sites More sharing options...
January 28, 201213 yr comment_379034 Yes, they will pop apart. Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379034 Share on other sites More sharing options...
January 28, 201213 yr comment_379040 A bit of lithium grease will make the job seam less brutal and make clean up go easier as well. Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379040 Share on other sites More sharing options...
January 28, 201213 yr Author comment_379046 Thanks for the quick responses, guys. I'll definitely try the lithium grease. Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379046 Share on other sites More sharing options...
January 29, 201213 yr comment_379048 If you want to get rid of that throttle surge and linkage slop, give this a try - easy mod and silky smooth throttle advance.http://www.srbymichael.com/manufacturers/lokar/lokar-throttle-kick.shtml Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379048 Share on other sites More sharing options...
January 29, 201213 yr comment_379049 Smooth linkage with low friction is so underrated. You don't know what you've been missing until the linkage is working properly. Going from a sticky linkage to a smooth linkage, changes the whole operation of the car. It even effects the infamous rear end clunk in a positive way.The ball end link will pry off with a flat screwdriver, and snap back on with a channel lock. I usually protect the plastic ball with tape first. Edited January 29, 201213 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379049 Share on other sites More sharing options...
January 29, 201213 yr comment_379058 Actually you should all try driving with a bare foot/sock at least once. You really can do very fine adjustments as the sensitivity to pressure increases awareness of where the throttle is. I guess wearing those F1 booties instantly make you a better driver just by the improved tactile feed back and sensitivity. Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379058 Share on other sites More sharing options...
January 29, 201213 yr comment_379064 Smooth linkage with low friction is so underrated. You don't know what you've been missing until the linkage is working properly. Going from a sticky linkage to a smooth linkage, changes the whole operation of the car. It even effects the infamous rear end clunk in a positive way.To each their own - I've had both and will not go back to the linkage.......have you tried the throttle cable? If you have not, then you do not know....and if you still have the rear end clunk there is a proven fix for that as well - fortunately I don't have linkage slop or rear end clunk........ Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379064 Share on other sites More sharing options...
January 29, 201213 yr comment_379098 With a Holley carb, I have a combination of lithium grease on the linkage and graphite powder on the cable, the same stuff you use for door locks etc. Proper lubrication is essential as noted by the others.When removing the linkages from each oter I use an open ended 10mm spanner under the ball. Even pressure is applied to both sides of the ball and it pops off without fear of breakage.Works for me! HaHaha. Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379098 Share on other sites More sharing options...
January 29, 201213 yr comment_379100 On your linkages be sure when you take them apart get some penetrating oil and spray each of the threaded ends, with a metal brush work the oil into the threads and work the adjusting nut so each of your links can be easily adjusted. When reassembling - snug up all your joints (including the firewall to the throttle pedal) so get as much slop out as you can. That is about all you can do to clean up and re-work the adjustments from the pedal to the carb. With all the adjustments and ball links - that is how the slop gets developed - all Z's have throttle surge due to the linkages (or at least 99 out of 100). It's been a problem since the original design. The throttle cable is a complete correction - one cable from the pedal to the carb - best of luck with your project. Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379100 Share on other sites More sharing options...
January 29, 201213 yr comment_379106 I don't dispute linkage versus cable. When I say "linkage", I mean anything in between your foot and the throttle plate. That does include your shoes. I imagine cables can be more reliable than mechanical joints. Whatever it is that you use, should be buttery smooth, and allow very small throttle changes with no "stepping". Smooth driving is imperative for performance. I have driven Z's with stock throttles, that made smooth driving impossible. I am sure there are many out there, that don't even realize they have an issue. Edited January 29, 201213 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/42095-todays-dumb-throttle-linkage-question/#findComment-379106 Share on other sites More sharing options...
