Posted January 29, 201213 yr comment_379121 Good Morning, My Dad has a stock 260Z and he's been talking about getting some webber carbs to replace his su's. Can anyone recommend good aftermarket carbs? Makes, models etc?Thanks,D~ Link to comment https://www.classiczcars.com/forums/topic/42107-aftermarket-carbs-for-a-stock-260z/ Share on other sites More sharing options...
January 29, 201213 yr comment_379127 Why not find some early SU carburetors? Contact Bruce Palmer via PM or go to Z Therapy. The side draft carburetors offer about the best performance for the Z. Link to comment https://www.classiczcars.com/forums/topic/42107-aftermarket-carbs-for-a-stock-260z/#findComment-379127 Share on other sites More sharing options...
January 29, 201213 yr comment_379128 Ditto on the SU's.There are far more articles / posts relating trouble with the Weber's and other downdraft carburators than ALL of the SU trouble threads combined.I'm not saying the SU's are infallible, just that once you get them set up right (or you learn how to), they're virtually trouble free. I haven't messed with mine in years, the old adage applies, if it ain't broke...Webers, and other downdraft carburators will require a new intake manifold... for starters, then you have to figure out the throttle linkage, then the choke connection (electric.. yeah right!) and THEN get them "tuned".It CAN be done, but if you're looking for relatively maintenance free, then the SU's are the way to go.E Link to comment https://www.classiczcars.com/forums/topic/42107-aftermarket-carbs-for-a-stock-260z/#findComment-379128 Share on other sites More sharing options...
January 29, 201213 yr comment_379138 So how fortuitous is that? You come on here asking this and 2 hours later a pictoral is posted covering what your answers here were spelling out.SUs and the Hitachi variant (re Datsuns) once returned to square one status, are the easiest carbs in the world to keep up with and the flat top conversion is a near bolt on conversion. Link to comment https://www.classiczcars.com/forums/topic/42107-aftermarket-carbs-for-a-stock-260z/#findComment-379138 Share on other sites More sharing options...
