My digital dash speedometer tends to not track speed very smoothly. For example; while accelerating the numbers may jump down a few, then go up a few before staying consistent on the speed. Is a normal function or should the speedometer track acceleration and deceleration perfectly smoothy and move through all numbers without jumping?
thanks again for humoring a newbie question.
  Quote
FWIW. I own an old Oldsmobile Bravada with a digital dash and it does that too. Not so much going down but jumps faster than it can count.
Regarding your signature: If you have the VIN or license plate number you can run a CarFax check for $18 that should state the location of the vehicle.
