Posted February 5, 201213 yr comment_379840 Can anyone post pics of weather stripping on the S30 doors? The only piece's I have left on my doors are the very bottom, underneath, and the very top of the window channel that meets the body. I am missing the ones that wrap around the window channel (front and back) where the channel meets the door. And the one that sits just inside close to the dash and top door hinge. The one that is held in place with 3 rivets. Those pics would be appreciated. Thanks. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/ Share on other sites More sharing options...
February 5, 201213 yr Author comment_379846 What the heck is "moulding"? I ment MOLDING. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-379846 Share on other sites More sharing options...
February 6, 201213 yr comment_379931 I'd love to see those pics too. I specially need big picture of door front w/s. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-379931 Share on other sites More sharing options...
February 16, 201213 yr Author comment_380891 Koalia, guess no one has the weatherstripping either. We are all probably missing it. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-380891 Share on other sites More sharing options...
February 16, 201213 yr comment_380897 Almost as good - http://www.carpartsmanual.com/datsunS30/DatsunZIndex/Body260Z280Z/2Seater/DoorMouldingFinisherArmRestMirror/tabid/1794/Default.aspx Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-380897 Share on other sites More sharing options...
February 16, 201213 yr comment_380907 I managed to install the front w/s but im missing the rear one. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-380907 Share on other sites More sharing options...
February 16, 201213 yr comment_380909 this? Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-380909 Share on other sites More sharing options...
February 17, 201213 yr Author comment_380984 Ah yes! perfect. Can you send one of the opposite end of the window frame where the frame meats the door also grantf? The really small piece. Is that original or did you have to replace it? Did you use regular W/S cement? Sorry for so many questions. I purchased new ones several years ago and when I attempted (recently) to install them I couldn't remember how to! Thanks for your help. I looked at the FSM but it doesn't make sense. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-380984 Share on other sites More sharing options...
February 17, 201213 yr comment_380986 The pic I provided shows the piece before I trimmed and glued it (only the upper portion) using lock-tight W/S cement, it is holding up nicely. The rear door peice I have not obtained yet so I can't help you there, sorry. Edited February 17, 201213 yr by grantf Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-380986 Share on other sites More sharing options...
February 17, 201213 yr Author comment_380998 No problem. Thanks for the help Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-380998 Share on other sites More sharing options...
February 17, 201213 yr comment_381017 These 2 are all I have, used the yellow 3-M Weather Strip Adhesive. Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-381017 Share on other sites More sharing options...
February 17, 201213 yr comment_381030 Here is a picture of the back area on my stock 76. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/#findComment-381030 Share on other sites More sharing options...
