February 17, 201213 yr Author comment_381039 Thanks Bonzi Lon, and mgood. Now I have what I need. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381039 Share on other sites More sharing options...
February 20, 201213 yr comment_381419 Thanks for the pictures! Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381419 Share on other sites More sharing options...
February 20, 201213 yr Author comment_381443 Would like to see pics of the same W/S pieces on a 280 door. Same view and angle. The 280 window frame is different from the earlier 240 and 260 Z's Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381443 Share on other sites More sharing options...
February 20, 201213 yr comment_381516 Make certain you have the door to fender seal because that will cause your car to leak into your floorboards pretty bad. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381516 Share on other sites More sharing options...
February 20, 201213 yr comment_381530 where can i purchase these seals? Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381530 Share on other sites More sharing options...
February 20, 201213 yr Author comment_381531 I got mine off e-bay Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381531 Share on other sites More sharing options...
February 21, 201213 yr comment_381546 Make certain you have the door to fender seal because that will cause your car to leak into your floorboards pretty bad.Agreed, I had a small swimming pool on the passenger side till I found and installed the seal. I would not expect it to make that big of a difference but it did. Even here in Seattle. I think I got mine from MSA. Edited February 21, 201213 yr by grantf Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381546 Share on other sites More sharing options...
February 21, 201213 yr Author comment_381567 Any special instructions grantf for installing the door to fender seal? Did you have to cut it? Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381567 Share on other sites More sharing options...
February 21, 201213 yr comment_381569 I am not really an expert on this one, but I can tell you what I did: I simply installed it without glue using the three plastic rivets, then glued only the upper portion using loctite W/S adhesive as if it were contact cement. then I trimmed the "square" section down to match the area were the SS trim meet the door body. I can post a finished pic one I replace batteries in my camera. Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381569 Share on other sites More sharing options...
February 21, 201213 yr Author comment_381573 Ok, cool. I will check back. Thanks Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381573 Share on other sites More sharing options...
February 21, 201213 yr comment_381589 Here's picture of weatherstrip on front part of door ........ area that slides under the fender! Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381589 Share on other sites More sharing options...
February 21, 201213 yr comment_381590 When I removed mine, I noted the factory had glued every square inch of each piece, had to be careful pealing off the small edges without tearing, and did not trim anything when they went back on. That little piece on the end can be confusing on how it fits. Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/42188-doorwindow-trim-moulding-pics/?&page=2#findComment-381590 Share on other sites More sharing options...
