Posted February 7, 201213 yr comment_380008 Just rebuilt carbs and can't get to idle right, runs at about 3000 rpm.None of the adjustments affect it. What have we done wrong?Thx Link to comment https://www.classiczcars.com/forums/topic/42204-carb-rebuild/ Share on other sites More sharing options...
February 7, 201213 yr comment_380059 A large source of unthrottled air will usually give you a runaway idle. You may have an air leak somewhere. The first place I'd check is where the carb mounts to the manifold. Link to comment https://www.classiczcars.com/forums/topic/42204-carb-rebuild/#findComment-380059 Share on other sites More sharing options...
February 7, 201213 yr comment_380081 Another thing to check is the throttle opener. If you have vacuum directly to this rather than through the control valve it will hold the throttle open enough to cause a high idle. Link to comment https://www.classiczcars.com/forums/topic/42204-carb-rebuild/#findComment-380081 Share on other sites More sharing options...
February 7, 201213 yr Author comment_380086 Thx guys. Link to comment https://www.classiczcars.com/forums/topic/42204-carb-rebuild/#findComment-380086 Share on other sites More sharing options...
