February 19, 201213 yr Author comment_381345 I uploaded a few picturs on snapbucket. Here are the links: http://pbckt.com/pr.NGNZ4T http://pbckt.com/pr.NGNbZDI just disconnected the electric water pump and electric fan from the ballast resistor and that didn't change how many volts are going to the back of the ignition switch. With them disconnected it read about 19 volts which is the same as the volts at the coil (and about the same with them connected to the ballast resistor) Way too high! I'm out of ideas to try... :disappoin Any suggestions? Anything I've missed? Thanks again!Richie Link to comment https://www.classiczcars.com/forums/topic/42235-back-of-ignition-switch-gets-hot/?&page=2#findComment-381345 Share on other sites More sharing options...
February 19, 201213 yr comment_381360 I would get a better voltmeter, or borrow one. I don't think that these alternators will even put out 22 volts, especially at low RPM. I think that your measurements are incorrect.The measurements from your Town Car confirm the bad readings, and secondarily, show that your Z car charging system is probably fine.It's not the voltage causing the heat, it's the amps that you're pulling through the switch with the fan and pump. You should install some relays to run those motors. Link to comment https://www.classiczcars.com/forums/topic/42235-back-of-ignition-switch-gets-hot/?&page=2#findComment-381360 Share on other sites More sharing options...
February 19, 201213 yr Author comment_381364 I'm willing to try anything for sure, but when I disconnected the electric fan and electric water pump (for a brief time ) the wires still got very hot and showed the same on the volt meter albeit possibly bad it at least shows consistency. How would I run relays to those electric motors? Richie Link to comment https://www.classiczcars.com/forums/topic/42235-back-of-ignition-switch-gets-hot/?&page=2#findComment-381364 Share on other sites More sharing options...
