Posted February 16, 201213 yr comment_380844 what do i need to do to switch from f.i. to carbs? i do not have any luck with the fuel injection system and just came across dual webber carb setup for a good price. Edited February 16, 201213 yr by stevec36 Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/ Share on other sites More sharing options...
February 16, 201213 yr comment_380846 - lower fuel pressure (change pump from high pressure to low pressure)-regulate fuel pressure to ~4 psi - Install fuel cut-off safety mechanismRemove-manifold- efi components Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380846 Share on other sites More sharing options...
February 16, 201213 yr Author comment_380849 efi components ?would that include the computer and distributor or just all the air flow meters and sensors?thanks for any info. Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380849 Share on other sites More sharing options...
February 16, 201213 yr Author comment_380850 would that include the distributor and computer or just the air flow meter and sensors? Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380850 Share on other sites More sharing options...
February 16, 201213 yr comment_380857 You will need the distributor and the ignition module.The rest can go:AFMInjectorsTVSFPRFuel RailECUElectrical HarnessDropping resistorsAARYou may also need a vacuum reservoir-type device for powering the brake booster. Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380857 Share on other sites More sharing options...
February 16, 201213 yr comment_380860 Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380860 Share on other sites More sharing options...
February 16, 201213 yr comment_380862 [ATTACH=CONFIG]51247[/ATTACH][ATTACH=CONFIG]51247[/ATTACH] Sorry just trying to get that smiley....It my be less work to try to understand and rectify youre efi. my 2 centsHow the hell do you post the popcorn eating smiley? Edited February 16, 201213 yr by grantf Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380862 Share on other sites More sharing options...
February 16, 201213 yr comment_380865 grantf : sent PM w/link. I have the image on my PC. Tried to send the GIF via PM- no go.Shhhhh...I want to watch this thread. It's gonna go for days. Edited February 16, 201213 yr by Willoughby Z Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380865 Share on other sites More sharing options...
February 16, 201213 yr comment_380889 Whats wrong with EFI. What year is it? I might want it. Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380889 Share on other sites More sharing options...
February 16, 201213 yr Author comment_380901 i did not mean to make an argument i just remember having a 240z and it got crashed so i bought a 280z and i have had issues with fuel injection since day 1 Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380901 Share on other sites More sharing options...
February 16, 201213 yr Author comment_380903 by the way popcorn kicks arse with beer Edited February 16, 201213 yr by stevec36 Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380903 Share on other sites More sharing options...
February 16, 201213 yr comment_380911 I know I am not answering you're question, but there are ways of getting the EFI system to perform well. Search the forum or ask what you're symptoms are and you will get help. But at the least you will need of course, a new intake monifold and carbs, but you know this already. Edited February 16, 201213 yr by grantf Link to comment https://www.classiczcars.com/forums/topic/42286-fuel-injection-to-webber-carbs/#findComment-380911 Share on other sites More sharing options...
