what do i need to do to switch from f.i. to carbs? i do not have any luck with the fuel injection system and just came across dual webber carb setup for a good price.
Edited by stevec36
- lower fuel pressure (change pump from high pressure to low pressure)
-regulate fuel pressure to ~4 psi
- Install fuel cut-off safety mechanism
Remove
-manifold
- efi components
You will need the distributor and the ignition module.
The rest can go:
AFM
Injectors
TVS
FPR
Fuel Rail
ECU
Electrical Harness
Dropping resistors
AAR
You may also need a vacuum reservoir-type device for powering the brake booster.
  Willoughby Z said:
[ATTACH=CONFIG]51247[/ATTACH]
Sorry just trying to get that smiley....
It my be less work to try to understand and rectify youre efi. my 2 cents
How the hell do you post the popcorn eating smiley?
Edited by grantf
grantf : sent PM w/link. I have the image on my PC. Tried to send the GIF via PM- no go.
Shhhhh...
I want to watch this thread. It's gonna go for days.
Edited by Willoughby Z
I know I am not answering you're question, but there are ways of getting the EFI system to perform well. Search the forum or ask what you're symptoms are and you will get help. But at the least you will need of course, a new intake monifold and carbs, but you know this already.
Edited by grantf
