Email logins are now active ×
Rebuild Transmission tool - Harber Freight 6 Ton A-Frame Bench Shop Press
tamo3
I'm thinking about rebuilding 71B 5Speed tranny before swapping with my automatic tranny.
In order to rebuild tranny, I'm thinking about buying shop press.
http://datsunzgarage.com/borg/
Datsun ZCARS mentioned 12tons press, but I was wondering 6 ton is good enough for it.
http://www.harborfreight.com/6-ton-a-frame-bench-shop-press-1666.html
I don't want more bigger tool occupied my garage.
Does anyone use this tool?
Thanks,
I found Youtube video to answer my question.
FS5W71B Assembly #1
FS5W71B Assembly #2
I thought I need shop press when pull a part from the largest shaft. It's around 14:53 on the video.
Looks like I don't need shop press.
Rebuild
Good videos! Wish there were some audio commentary explaining what is being done, but otherwise good. These should be linked/saved for future access by others doing their own rebuild. I have done a couple rebuilds without using a press, but if you have access to one, it makes life easier. If you have a few pieces of pipe, etc, some patience, ingenuity, and time, you can do it yourself. The last one I did, I bought the rebuild kit with bearings, synchros, gaskets, etc for about $150 from Autozone, and knocked it out in a weekend.
Yes, the video is really helpful. Thanks for Villegeland for posting video onto Youtube.
When I research price of rebuild kit, the cheapest rebuild kit is at eBay.
Drive Train.com $160.98
http://www.drivetrain.com/parts_catalog/manual_transmission_overhaul_kits/nissan_f5w71_overhaul_kit.html
Z Specialties $374.95!
http://www.datsunstore.com/product_info.php/pName/trans-complete-rebuild-kit-wsyncros-5-speed-18-piece-7780/cName/drivetrain-z
AutoZone.com $161.99
http://www.autozone.com/autozone/parts/Atc-Pro-King-Manual-Transmission-Rebuild-Kit/1977-Nissan-Datsun-280Z/_/N-indg1Z6o2tw?itemIdentifier=884620_23477_5208_6577
eBay.com - seller is acerl $124.95 +CA Tax
http://www.ebay.com/itm/Nissan-Car-5-Spd-FS5W71A-Transmission-Rebuild-Kit-77-80-/370407968363?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ANissan&hash=item563e090e6b&vxp=mtr
Looks like I need to find 5th gear black fiber 5th gear "crush style" synchro ring separately.
http://forums.hybridz.org/index.php/topic/101424-transmission-rebuild-kits/
I wonder where I can purchase it from.
factorynissanparts.com does not allow to search older than 1980 car parts...
Did anyone recently purchase 5th Syncro ring?
Thanks,
tamo3
Edited by tamo3
