Posted February 19, 201213 yr comment_381314 I wanted to give a shout out to Metal Rescue. I just took some suspension parts out of an overnight bath in this solution and was very pleased with the results. All the parts are rust free after the bath and clean up was a simple wash down in the tub. Gloves are not even required.It wasn't cheap but it's a lot cheaper than Dremel parts and my time. I'll be buying more for the rear suspension cleanup.http://www.metalrescue.com Link to comment https://www.classiczcars.com/forums/topic/42333-metal-rescue-rust-remover/ Share on other sites More sharing options...
July 24, 201312 yr comment_428379 78sid said: I wanted to give a shout out to Metal Rescue. I just took some suspension parts out of an overnight bath in this solution and was very pleased with the results. All the parts are rust free after the bath and clean up was a simple wash down in the tub. Gloves are not even required.It wasn't cheap but it's a lot cheaper than Dremel parts and my time. I'll be buying more for the rear suspension cleanup.http://www.metalrescue.comWe appreciate the shout out, if you have any questions about Metal Rescue, or rust removal please don't hesitate to ask. Link to comment https://www.classiczcars.com/forums/topic/42333-metal-rescue-rust-remover/#findComment-428379 Share on other sites More sharing options...
