Posted February 19, 201213 yr comment_381324 Are the 77 and 78 dash gauges interchangeable? Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/ Share on other sites More sharing options...
February 19, 201213 yr comment_381369 Totally. Functionally in every way. Same mounting. Connectors are the same too. There was a font change on the gauge faces, but I think that happened sometime in 76-77 transistion. Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381369 Share on other sites More sharing options...
February 20, 201213 yr Author comment_381374 Cool! Thanks Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381374 Share on other sites More sharing options...
February 20, 201213 yr comment_381446 I thought the 78 Speedo has a thing on the back that affects the emmissions? I think it connects to the BCDD? Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381446 Share on other sites More sharing options...
February 20, 201213 yr Author comment_381448 I will check with my Z mechanic buddy today and post what I find. Thanks TomoHawk. How is your EFI system performing? Mine suck's right now! Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381448 Share on other sites More sharing options...
February 20, 201213 yr comment_381449 If there is additional components on the speedo, would be simple to transfer the sensor package on the back to the new one. Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381449 Share on other sites More sharing options...
February 20, 201213 yr Author comment_381451 My thoughts also zKars. Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381451 Share on other sites More sharing options...
February 20, 201213 yr comment_381454 My EFI is working just fine. The engine isn't so happy when I try to start it in 30-degree air tho. Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381454 Share on other sites More sharing options...
February 20, 201213 yr Author comment_381459 Do you have strick smog laws out there in Ohio? We do here in CA. 0.5% CO at idle and part throttle. That is really lean for my Z. And it is stock. Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381459 Share on other sites More sharing options...
February 20, 201213 yr comment_381464 Yes, there are smog laws, but no smog ether. Ohio has beautifully clean air, unless you live downwind to a cow-barn or pig-barn. Link to comment https://www.classiczcars.com/forums/topic/42335-77-78-gauges/#findComment-381464 Share on other sites More sharing options...
