Posted February 19, 201213 yr comment_381362 I have read around the net that when running coil overs you should install the bump steer spacer set. Is this also true when running the 1" drop from the Tokico struts and springs on the 240? Just want to make sure I have all the correct parts before I re assemble. Thanks Link to comment https://www.classiczcars.com/forums/topic/42338-bump-steer-spacer-with-tokico-kit/ Share on other sites More sharing options...
