Posted February 20, 201213 yr comment_381498 hey everybody im upgradeing my headlights 1 i cant find the the plug for the wire harness to go to. trying to find out if i need to splice it in.2 im putting in a hid kit in and if i even need to put it in for that any help is much appreated. ill put up pics of the new lights soon. Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/ Share on other sites More sharing options...
February 20, 201213 yr comment_381500 What year car? Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/#findComment-381500 Share on other sites More sharing options...
February 20, 201213 yr Author comment_381506 o crap sorry its a 78 280 base sorry i forgot the specs i always forget one thing Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/#findComment-381506 Share on other sites More sharing options...
February 20, 201213 yr comment_381514 Hey Silvey,If you are talking about the Headlight Heavy Duty Harness 70-040, it just plugs into the original headlight bulb connector. I have this installed on my car, works great. Be sure and wrap it with black electrical tape before you install it, if you don't want that yellow wire loom to be so noticable. Bryce Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/#findComment-381514 Share on other sites More sharing options...
February 21, 201213 yr Author comment_381550 ok but now getting the connector out of the light bucket ill just have to expand the hole a bit.i wanna up grade this befor i do the wireing for the HID kit. i just wanna be safe so i dont burn anything out. Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/#findComment-381550 Share on other sites More sharing options...
February 21, 201213 yr comment_381601 Actually, you don't have to expand the hole if it is like my 73. I just carefully removed each pin from the connector, after noteing location of wires, and slipped the terminals through the hole separatly. On the other side of the bucket all you have to do is reinstall the terminals into the connector.Bryce Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/#findComment-381601 Share on other sites More sharing options...
February 26, 201213 yr Author comment_382145 i had to expand them for the HID bulb the back was hitting but its ok a little grind and problem solved i installed the kit with no problem and its working great my lights are super bright now. Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/#findComment-382145 Share on other sites More sharing options...
February 26, 201213 yr comment_382150 It's amazing how safe you feel behind the wheel when you can actually see the road, I didn't go projector but relays and halogens sure beat the 5 candel power highbeams I started with. Link to comment https://www.classiczcars.com/forums/topic/42354-bd-headlight-wire-kit/#findComment-382150 Share on other sites More sharing options...
