So I jacked up my Z on the drivers side the other day to inspect the tie rod boot (which turned out to be fine) in attempt to diagnose some high speed steering wheel shimmy. After setting the car down and jumping in I immediately noticed the steering wheel was off to one side. Upon driving I found there to be almost no steering recoil after making a turn. I turn the wheel, let go, and it stays in that position without returning to center.
After some research I found this to be a common symptom of bad/worn lower ball joints - so I replaced them with MSA pieces. Unfortunately the new ball joints did not solve the problem. My next step is to look at the tie rods or rack bushings since the wheel shifted off center something with the rack or tie rods had to have shifted as well. I know the wheel failing to recoil points to a caster problem, however as far as I understand caster is not adjustable on our cars. Also, I can visually see the camber is off, the drivers side seems to nearing positive while the passenger side seems ok. Camber is non-adjustable as well, correct? What would cause a shift in camber/caster on these cars?
Any info is greatly appreciated as the car does not feel safe to drive at the moment (I have another daily).
https://www.classiczcars.com/forums/topic/42371-weird-240z-steering-issue/
