Posted February 23, 201213 yr comment_381768 Is a refurbished brake booster from a 280z at Orileys or Autozone a direct replacement for a early 240z with the smaller booster? Since I have everything out for paint I noticed the booster is very corrodid and seems to be the original. It may have been leaking, so i think it would be best to replace. Will there be a benefit to using the larger booster besides the fact I can not find the small early ones for as cheap? Link to comment https://www.classiczcars.com/forums/topic/42377-later-brake-booster-on-early-240z/ Share on other sites More sharing options...
February 23, 201213 yr comment_381798 The holes through the firewall will not match up. You'll have to measure and drill through the firewall, and I would use some insulation to block off the holes. I did this conversion, and it is very straight forward. If done right it should be a clean outcome. Link to comment https://www.classiczcars.com/forums/topic/42377-later-brake-booster-on-early-240z/#findComment-381798 Share on other sites More sharing options...
February 23, 201213 yr Author comment_381800 thanks a lot. Hopefully Orileys will have the 8" booster in stock when I go to pick one up. Did you notice any more assist in your brakeing from the larger booster? Link to comment https://www.classiczcars.com/forums/topic/42377-later-brake-booster-on-early-240z/#findComment-381800 Share on other sites More sharing options...
February 23, 201213 yr comment_381801 Don't overlook getting your original booster rebuilt locally. It may be a wash on $.Jim Link to comment https://www.classiczcars.com/forums/topic/42377-later-brake-booster-on-early-240z/#findComment-381801 Share on other sites More sharing options...
February 23, 201213 yr comment_381807 thanks a lot. Hopefully Orileys will have the 8" booster in stock when I go to pick one up. Did you notice any more assist in your brakeing from the larger booster?It is hard to say because I upgraded to Wilwoods all around, and a Wilwood 1" Brake Master Cylinder at the same time. I have seen people say it is a worthy upgrade though, and that there is additional brake assist. Link to comment https://www.classiczcars.com/forums/topic/42377-later-brake-booster-on-early-240z/#findComment-381807 Share on other sites More sharing options...
February 23, 201213 yr Author comment_381815 looking at the grungy old thing makes the decision to replace it easy especially since i have spent the last year grinding scraping and cleaning every other parts on the car during the teardown. also if it gives any better brake response than the tiny unit that came in the series one cars I am all for that also. thanks again for everyones input Link to comment https://www.classiczcars.com/forums/topic/42377-later-brake-booster-on-early-240z/#findComment-381815 Share on other sites More sharing options...
February 24, 201213 yr comment_381862 Last I checked rebuild parts were available. As for the body, blast, paint, powdercoat = beautiful... Link to comment https://www.classiczcars.com/forums/topic/42377-later-brake-booster-on-early-240z/#findComment-381862 Share on other sites More sharing options...
