Hi guys,
Ok, so I'm looking at a project this year. My car is fully restored and I've got triple Mikuni's installed. It's a great system, but, just coughs and sputters a bit too much for me. I have a full EFI system out of a 78 280z including computer and intake with brand new injectors. Does anyone have a tech article on making the swap happen? That said, is it possible to use my existing fuel supply piping and fuel tank (I've got a '71)?
Mike
https://www.classiczcars.com/forums/topic/42416-conversion-to-efi-from-carb/
I agree with everything you say about the old system except for the part about it being an "an antiquated and delapidated piece of junk". Antiquated; definately, dilapidated (you used the very common misspelling) would depend on the particular example. Aging, failing, changing components (or I believe the word 'drifting' has been used) are what eventually cause problems in these systems. With the unavailability of new parts, it's difficult to get one to run correctly. One of the reasons I sold mine. They were both low mileage examples the functioned as the factory intended. I never had the problems the I've seen reported here but I knew that in the future I likely would have. But in reality, Webers, S.U.s, Mikunis, etc. are also antiquated. But they are, arguably, easier to work with. I'm not really sure that installing all of the sensors, etc. required to run a modern system on an engine that is also, let me say it nicely, a part of history, would be the answer either. People have done it but it has is drawbacks also. If it has carbs keep it carbureated.
Edited by sblake01
Mike,
As everyone here as pointed out the stock EFI system is, well old and out of date. It was a great feature of the 70's but its just not up to par with everything out on the market. I recently did a megasquirt (MS) upgrade on my Z as my old EFI system was leaning out and stalling and I just wasn't going to deal with trying to fix it anymore. The install took about two days (roughly 14 hours or so but I was taking my time). The only warning I have is do your homework before getting it. The install is simple enough the tuning is where people have issues. MS can control pretty much everything on the engine from injectors to the timing, its just a matter of how far you want to go. I just have it controlling the injection for now. Here is how my engine bay looks now (its about 80% complete. I "tried" to make the wiring look stock like, it came out ok in my opinion).
Jan
So how does it run right now?....good?
Is that aimed at me? It runs amazing and that's not an understatement. I don't have dyno results but from the "feel of my seat" dyno I definitely have more power (or at least the power I'm supposed to have) at all RMPs. The throttle response is better and fuel economy is up a tad, though I think I have a case of lead foot now. :-).
Jan
Jan
Did you do version 2? Just go with a map sensor, or a wideband as well?
Thanks guys, are there websites for the aftermarket systems you recommended? Although I like the idea of EFI, I like the simplicity of my engine compartment with the triples on there now. It looks neat and clean.
I remember seeing an aftermarket system on a Z at the Canby show that was very clean. The guy replaced the distributor with some kind of mechanical sensor on the crank and low voltage all the way up to the spark plug. Like a modern system, the high voltage spark isn't transferred over wires, each spark plug has a mini coil on top of it.
My goal is to make the car easier to drive while keeping the engine bay clean. I would like something that looks like it was delivered in the 70's. I believe there are some nice EFI photos in the gallery and I'll have to post a few here.
Recently Browsing 0
