techno toy tunning tc rods
kully 560
Thanks. I just ordered the TC Rods and LCA's from TTT, (how's that for abbreviations) since my caster was not equal for the front wheels and I did not want the control arms to bind.
I'll report back once they are installed.
let me know how the lca work out looks like a nice product. I do not know how much camber you can adjust with the lower control arms ,some I think . because I believe the tie rods will not give to much adjustment ,but a little is better then none.if you need more caster than the adjustment tc rods can give you can stick a few washers inbetween the ubracket and the machined washer provided you will see when you recieved them kurt
You can buy turnbuckles from www.colemanracing.com in various lengths. Just get a longer turnbuckle if you want to adjust in a lot of caster.
Agree with the camber comment though. There isn't a lot of extra threads in the stock tie rods. I wouldn't make a big camber adjustment without double checking the threads and making sure there were enough. Engineering rule of thumb is 1.5x the diameter engaged.
  • Who's Online   1 Member, 1 Anonymous, 575 Guests (See full list)
