I have a very peculiar noise,sound like SIP,,,,SIP,,,SIP it is intermittent , seems to came from the rear and appears when I make left turns only. In my mechanical limited abilities I sanded down the rear brake shoes and drums , the both look fine no evidence of rubbing, this SIP...SIP...SIP is making me nuts .My car has a complete suspension refresh done 4k ago, bearings, rubber bushings, struts plus a complete brake job,lines and MC, the exhaust system is also refresh and is not rubbing.:disappoin
Edited by 72 OJ
https://www.classiczcars.com/forums/topic/42424-i-have-sip-sip-sip-noise/
Are you running hubcaps?
Sounds just like the noise my 73 made when the "grippers" on the outside edge of the hubcap had loosened enough to let them slip ever so slightly as I drove.
Took the hubcaps off all wheels, sprung the "grippers" just a little to make better contact with the inside of the rim and reinstalled.
No more "sip-sip-sip".
Took me a week to figure that out!
YMMV---FWIW
Jim D.
"Zup"
