I did buy a MSA performance muffler 2 1/2 inch with a 3 into 2 Header for my 71 240Z
there is no flow indication on it
there is one side with the Hole in the center and the other side the hole is not centered
It would fit better under the car with the center hole in the front and the offset hole in the back
but i am not sure witch way to install it.
Thnk's
jeanp - great to know you just got them too! I just pick up the same set (MSA 3-2 header, MSA performance exhaust) and can't wait to put them on. Let us know how the install went (now that you know which way to put the muffler on!)
