Posted March 9, 201213 yr comment_383428 Has anyone thought of setting up SU's to run E85? Is it even possible? Would the nozzle be the only issue? Just curious.. Link to comment https://www.classiczcars.com/forums/topic/42549-e85/ Share on other sites More sharing options...
March 9, 201213 yr comment_383469 I think a bigger issue might be replacing the rubber parts in the fuel system to those that can tolerate a higher alcohol content. Isn't there a rubber diaphragm in the mechanical fuel pump? Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-383469 Share on other sites More sharing options...
March 9, 201213 yr Author comment_383558 Big rubber gasket in the mechanical pump. I'm running an electric pump but I'm sure there is rubber in there somewhere. I would think the steel fuel tank, needle and seat assembly at the float, and the nozzle would be the main obstacles. I've noticed a couple of companies building E85 capable 4150 Holley carburetors. It would be neat if someone(Bruce) made an E85 Hitachi. Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-383558 Share on other sites More sharing options...
May 14, 201212 yr comment_390040 I have a couple questions, why would you want to run e85 in your engine?I have a 2009 Suburban which runs flexfuel, pump gas or e85. I used to use e85quite a bit and found no advantage to it. My mileage dropped, my horsepower dropped,and cost-wise, for a cent or two per mile less, had to fill up more often, and less pick-up.The price in my opinion is a scam. As the gas prices go up, the e85 price tracks rightalong with it, although it contains up to 85% ethanol. The gas part, even if it doubled,shouldn't raise the overall price of the fuel that much. I'm totally convinced the numbersare artificial.I was lead to believe the problem with the rubber had to do with methanol, not ethanol,am I wrong?Pardon me for jumping in here, couldn't resist.Jim Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-390040 Share on other sites More sharing options...
May 14, 201212 yr comment_390042 I was lead to believe the problem with the rubber had to do with methanol, not ethanol,am I wrong?JimThere is a saying, "The dose makes the poison." Higher levels of ethanol will affect rubber more than lower concentrations. I would also speculate that the higher level of ethanol would allow more water absorption into the gasoline, increasing corrosion in the steel components, as well. Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-390042 Share on other sites More sharing options...
May 15, 201212 yr comment_390138 You can run a lot more compression ratio and/or boost, and ignition timing with E85. Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-390138 Share on other sites More sharing options...
June 26, 201212 yr comment_394120 John:You are right about the higher compression ratio, that's mainly why alcohol is used in indy cars,but they are using methanol. I worked 32 years on the circuits, did fire/rescue. I workedin the pits along with all of the big boys. The indy people also claimed it was safer than gasoline, probably true, but you couldn't see the flames. You sawdrivers dancing on the ground, paint wrinkling, shadows of the heat waves, grass burning,clothing starting to burn, etc. but the good thing, plain ole water put it out and cooled too.Also, what is fuel drier? Nothing more than alcohol, since it has an affinity for water.Here on the left coast there is no source for ethanol. It all comes from the midwest, shippedout in tanker cars, then blended locally with gasoline to produce e85. There was a facilityin Stockton, CA that processed ethanol but it closed down.Don't want to get political here, but e85 is a scam, I went back to gasoline. I bought some regulara couple days ago for a discounted price of $4.65 a gallon, and I remember gas wars years ago ofless than 24 cents a gallon.Jim Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-394120 Share on other sites More sharing options...
June 26, 201212 yr comment_394138 Actually, Indy cars switched to ethanol in 2007. Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-394138 Share on other sites More sharing options...
June 26, 201212 yr comment_394139 This has nothing to do with the OP's question, but Tim Zwicky was running E85 in his Tec III FI turbo 280Z. The last I talked to him, he was around 700 RWHP. He did it to run more spark. Link to comment https://www.classiczcars.com/forums/topic/42549-e85/#findComment-394139 Share on other sites More sharing options...
