Where to Find Ignition Module
sopwith21
Okay, module is here.
Now... there are two wires that plug into it. One of them goes directly to the coil and there is only one option on how and where to plug it in.
The other wire is a small wire coming from the distributor itself. But there are two possible female receptacles on the back of the ignition module where it could be plugged in... which one do I use? Thanks.
