Posted March 10, 201213 yr comment_383624 Fellow Skyline owners, (I'm still getting used to how that sounds... ...) How many of you have the optional MK63 4piston calipers on the front of your Skyline? While you may be running 15" or larger diameter wheels, have you tried fitting 14" steelies over these calipers? Did your car come with a 14" steel spare in the trunk? Let me know please, Thanks. -e Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/ Share on other sites More sharing options...
March 10, 201213 yr comment_383663 was that a gtr option?? remember you can fit anything anywhere with the right adjustments Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383663 Share on other sites More sharing options...
March 11, 201213 yr Author comment_383724 they are also known as the FIA Caliper option that was available through Nissan's competition department back in the day...So not a factory installed option, but instead a factory available racing option.Do you have them on your car? Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383724 Share on other sites More sharing options...
March 11, 201213 yr comment_383731 Eric,I have vented type MK63s on the front of my KPGC10, and I think you might find that a slim spacer is needed if you want to bolt a stock steel wheel over them. Most alloy wheels - even 14" diameter - will fit over them. They have to be wheels with a really thick rim, or a very weird offset, to foul the calipers. Nissan made a special alloy shim spacer for just this purpose, and listed it in the Sports Options parts lists for the PGC10 and KPGC10. Part number was SPACER WHEEL 40209-A0220. It was just a very simple shim spacer, about 3mm thick, that slipped over the wheel studs on the hub and was sandwiched between the wheel and the hub. The kind of thing you can still pick up from a wheel specialist today. Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383731 Share on other sites More sharing options...
March 11, 201213 yr comment_383737 Jogged my own memory, and dug out the JAF/FIA homologation papers for the KPGC10. Nissan went to the trouble of homologating the spacers for race use. There were actually three thicknesses available: 2mm, 5mm & 10mm. As you might be able to see from the photo on the homologation papers, they even went to the trouble of stamping the Nissan 'hamburger' into each piece to denote authenticity. Centre bore was 77mm to clear the hub. Are you going to be using stock steel wheels on the car ( occasionally? ), or is this more about carrying a spare wheel that will fit over the calipers? Forum won't allow me to upload images at the moment ( ??? ), so here's the page on Imageshack: Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383737 Share on other sites More sharing options...
March 12, 201213 yr comment_383780 ^^^ wow!! Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383780 Share on other sites More sharing options...
March 12, 201213 yr comment_383791 no I have my great aunts auto 240k so no standard goodies. But I was wondering if it's an acceptable practice to put a spacer between the 2 half's of the standard 2 pot callipers (I'm assuming they are 2 piece) to fit them over vented disks? Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383791 Share on other sites More sharing options...
March 12, 201213 yr comment_383808 But I was wondering if it's an acceptable practice to put a spacer between the 2 half's of the standard 2 pot callipers (I'm assuming they are 2 piece) to fit them over vented disks?that was the "sports option" for 1200(sunny)b110's in japan(and america?). Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383808 Share on other sites More sharing options...
March 13, 201213 yr Author comment_383920 Hi AlanThis is just for spare tire purposes only.My C10 currently does not have a spare and with the 700mile drive I need to do with the car in a couple weeks I don't want to run the risk of getting a flat in the middle of the desert.Glad to hear 14"s (with a wheel spacer) will fit over MK63 calipers...I'll order one up today.Thanks Alan.-e Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383920 Share on other sites More sharing options...
March 13, 201213 yr comment_383925 It might be a good idea to take a couple or three shims of different thicknesses to 'stack' as necessary. There might be some variation on steel wheel clearance, depending on what wheel you take.Don't forget to take some stock - open-ended - M12 x 1.25 wheel nuts too. The closed end ( Watanabe? ) wheel nuts might not work with a steel wheel.Good luck with the journey home!Cheers,Alan T. Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383925 Share on other sites More sharing options...
March 13, 201213 yr Author comment_383929 Definitely will do...Thanks Alan.-e Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-383929 Share on other sites More sharing options...
March 23, 201213 yr Author comment_385147 Quick FYI update guys:I had the opportunity to try out a stock 89-94 240SX 15x6 steel rim over the MK63 calipers.It cleared the caliper but required a 5mm wheel spacer not to rub due to the 240SX' different offset.Stock C10 rim size was 14" with 6.45 s14 tires which equates to a 175/70R14 or 185/65R14Maybe this is useful info for someone else? Link to comment https://www.classiczcars.com/forums/topic/42566-minimum-wheel-size-for-mk63-calipers/#findComment-385147 Share on other sites More sharing options...
