January 15, 200322 yr comment_23384 Why can't you inspect the floorpan? The carpet should be hooked around a couple of catches under the seat - once you unhook the carpet it should lift right up... Link to comment https://www.classiczcars.com/forums/topic/4257-buy-opportunity/?&page=2#findComment-23384 Share on other sites More sharing options...
January 16, 200322 yr Author comment_23420 Oooops, my bad, will do. Thanks Link to comment https://www.classiczcars.com/forums/topic/4257-buy-opportunity/?&page=2#findComment-23420 Share on other sites More sharing options...
January 17, 200322 yr Author comment_23537 Well, I now have the Z Straight trade, no extra money invested. Good by civic, hello Z -Ben Link to comment https://www.classiczcars.com/forums/topic/4257-buy-opportunity/?&page=2#findComment-23537 Share on other sites More sharing options...
January 17, 200322 yr comment_23540 Now that you've obtained your Z, you have taken the first step in something that will give you hudnreds of hiours of enjoyment and unfortunately, a few not so enjoyable hours here and there.Take care of your car, look it over carefully and learn all you can about it, as that knowledge is what will save you much money and avoid frustrations.This is one of the best sites for that. Research the archives, but feel free to ask questions. The search feature will yield faster results than posting the same question over again. But if you truly have a new spin on an old question, feel free to post your query to the ORIGINAL question. Mike has programmed all new posts to pop up on the home page as ACTIVE POSTS and you will get more information with an old post that is refreshed this way, than if you were to post the question as new.Additionally, by keeping all subsequent questions to an item together (i.e. the same post) when new searches are done, not only the older answers but also your new spin on the item will all be presented together.Again, Welcome!Enrique Scanlon Link to comment https://www.classiczcars.com/forums/topic/4257-buy-opportunity/?&page=2#findComment-23540 Share on other sites More sharing options...
