laying dynomat tips
KAL7467
Tips:
Its tedious and boring, beer helps
Warm weather helps. If its cold try storing the dynomat in the house before application
It doesn't need to be installed 3 layers thick like the audio forums show
I like to pull the backing off about an inch at first then remove as its being installed to prevent accidental sticking
Measure twice, cut once. then swear and cut again, see tip #1
Really sharp scissors work well for odd shapes
dont be afraid to put in a relief cut, it doesnt need to be water proof so shape it like fabric
Dynomat makes a $10.00 wooden roller, if you don't have one, get one. It makes laying it much easier. I precut the pieces, relief cuts and all prior to removing any backing and when I do, I do like Kurbycar32 stated, roll back a little at a time, roll it flat and then remove a little more backing. I find that it takes about 2 beers per sheet, just a reference of course.
Bit late now, but for the next person who finds this thread, I've had excellent succes with a product called "B-Quiet Ultimate" from
http://www.b-quiet.com/ultimate.html.
Easy to apply, forgiving during install, and very conformative. The cost is also much easier to bear.... And it works. They have a full line of sound control products. I have used their stuff on several projects now, including my own. Only down side is getting it off when you later find some rust repair that needs to be done. Don't ask how I know....
Love the beer speed reading for this job...I can now understand how much time it will take to get this job done.
I used Megamat that was made out of butyl. 100% synthetic, sticks perfectly and zero smell. The traditional dynomat is made out of basically roofing tar so its got a bad reputation for stench. Butyl is also completely air-tight once its adhered so it should in theory make it impossible to rust from the inside. Just to be sure though i coated the interior steel with a rust proofing paint
Edited by Kurbycar32
i think i am using either rammat or fatmat not really sure has been about a year since I bought it...I do have the roller and have been using cuts to make it lay flatter ...thanks everyone for the input. cant wait to be done with this boring yet necessary task
  • Who's Online   2 Members, 0 Anonymous, 493 Guests (See full list)
