Posted March 17, 201213 yr comment_384432 I want to take my S30 block to the machine shop for some work. But I am worried about the oil pressure bypass valve. Some shops in California do not hot tank to clean, they bake the block at very high temp.Should I remove the valve and replace with new or will it survive a hot tanking or a baking? It looks like it would be destroyed by prying it out of the block.Also, what is the best way to clean the carbon off the tops of the pistons?One more. I am removing the oil gallery plugs. Are the replacements called Dowels? That is all I see listed at Zsource and Motorsports.ThanksMike Edited March 17, 201213 yr by mbarjbar Link to comment https://www.classiczcars.com/forums/topic/42653-oil-pressure-bypass/ Share on other sites More sharing options...
March 17, 201213 yr comment_384455 Get the machine shop to drill and tap the galleries for threaded plugs. Link to comment https://www.classiczcars.com/forums/topic/42653-oil-pressure-bypass/#findComment-384455 Share on other sites More sharing options...
March 19, 201213 yr Author comment_384540 Am I the only one who has had this problem?? Link to comment https://www.classiczcars.com/forums/topic/42653-oil-pressure-bypass/#findComment-384540 Share on other sites More sharing options...
March 19, 201213 yr comment_384568 I just had my N42 hot tanked and I've never read anything about a oil pressure valve. But that doesn't mean too much. I used a 5 gallon bucket with about 1" of lacquer thinner in it. All 6 pistons fit perfect, face down, so I let them soak overnight and then scrubbed them with a ScotchBrite pad. Worked great. Stored them in another 5 gal. bucket with a good soaking of WD-40 then put the lid on. Edited March 19, 201213 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/42653-oil-pressure-bypass/#findComment-384568 Share on other sites More sharing options...
