Posted March 19, 201213 yr comment_384553 underneath the carpet in the luggage area, facing to the front of the shock towers and behind tool compartment,are two holes that look like speaker holes. The P.O. had sheet metal riveted over top of them, covering them up. Is there a reason for these? Can they be covered and welded closed? Thank you, Timsz Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/ Share on other sites More sharing options...
March 19, 201213 yr comment_384556 Pictures? Year/Model of Car?? Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/#findComment-384556 Share on other sites More sharing options...
March 19, 201213 yr comment_384564 From his profile, it looks like Tim might have a 71. I know another member here is restoring a 71 that has holes in the rear deck for 6x9s cut by a PO. Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/#findComment-384564 Share on other sites More sharing options...
March 20, 201213 yr Author comment_384690 I was tired. Sorry. Yes I have a 71 240Z. I'll get pics. Thanks, Timsz Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/#findComment-384690 Share on other sites More sharing options...
March 21, 201213 yr comment_384859 Big, rectangular holes? Those are the tool box holes. There should be hinged lids on them, at least on most models. On the '77/'78 models, we just have vestigial holes, covered up by the stupid false floor. You could indeed mount a couple of 6x9 speakers in the compartments and have the whole thing completely reversable to stock -- as long as you remove the toolbox lids and cut up something else. Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/#findComment-384859 Share on other sites More sharing options...
March 22, 201213 yr Author comment_384957 thanks F.W. Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/#findComment-384957 Share on other sites More sharing options...
March 22, 201213 yr comment_384970 Depends - if your "71" is a Series I example - the tools were mounted behind the seats, with plastic covers over them. In the Series I cars there were holes in the forward section of the rear deck area. These were usually covered with a tar mat. If your "71" is a Series II example - then the tool storage was in that forward section of the rear deck - with hinged lids covering them.That is why posting a picture of what you have would be helpful..FWIW,Carl B Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/#findComment-384970 Share on other sites More sharing options...
March 27, 201213 yr comment_385472 Could it perhaps be a in between series car that has the holes cut in the deck but the plastic tool holders behind the seats as well..? I think you mentioned something like this in another post Carl? Link to comment https://www.classiczcars.com/forums/topic/42662-luggage-area-holes/#findComment-385472 Share on other sites More sharing options...
