does any one know off hand what the bolt size is that bolts the engine to the trans . ? I need to mount an engine to a engine stand and both are an hour away and if some one knew off hand it would sure save me some time Thanks Gary
https://www.classiczcars.com/forums/topic/4269-bolt-size-question/
Thread is 10M X 1.5
(3/8 unc will sorta kinda fit but you could wind up damaging the threads)
Length is determined by the mounting thingos on the engine stand. If unsure just get some long bolts and a stack of washers.
