Posted March 23, 201212 yr comment_385154 The 1978 280z windows are attached to the window regulator by 4 machine screws. Does anyone know the thread pitch and length of the screws?Thanks in advance Link to comment https://www.classiczcars.com/forums/topic/42724-1978-280z-window-fastners/ Share on other sites More sharing options...
March 24, 201212 yr comment_385196 i assume you mean the screws that hold the glass to the crank system. I was missing one screw and used a stainless 10/32nd 1" bolt and nut to attach it with a rubber and metal washer on both sides and it holds great Link to comment https://www.classiczcars.com/forums/topic/42724-1978-280z-window-fastners/#findComment-385196 Share on other sites More sharing options...
March 24, 201212 yr Author comment_385226 Thanks for the info. I went to ACE and got 8 5 mm .080 pitch in stainless. they will work great. Link to comment https://www.classiczcars.com/forums/topic/42724-1978-280z-window-fastners/#findComment-385226 Share on other sites More sharing options...
