Posted March 27, 201213 yr comment_385447 Just order this one. http://www.meritline.com/red-led-6-bulb-light-strip---p-72208.aspx It can be good addition for room break light. Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/ Share on other sites More sharing options...
March 27, 201213 yr comment_385452 Did you buy it? Any photos? Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-385452 Share on other sites More sharing options...
March 27, 201213 yr Author comment_385460 I just ordered today. Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-385460 Share on other sites More sharing options...
March 28, 201212 yr comment_385520 Would love to see this installed. Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-385520 Share on other sites More sharing options...
March 28, 201212 yr comment_385530 The 60- LED blue string might be nice to light up the engine bay when you open the bonnet. Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-385530 Share on other sites More sharing options...
March 28, 201212 yr comment_385548 I use the LED self stick string for a 3rd light. It's totally non intrusive when it's off. Stuck to the hatch glass rubber surround. Edited March 28, 201212 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-385548 Share on other sites More sharing options...
March 28, 201212 yr comment_385559 That looks cool. Where do you get those? How did you wire it? Do you leave the wiring hanging, or does it hide away when you don't want top use the brake lamp. Edited March 28, 201212 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-385559 Share on other sites More sharing options...
March 28, 201212 yr comment_385560 The thin wire is already covered in black braid, and I bundled it with the wire for the rear defrost. The I tucked the wire inside the roof trim and the rear quarter trim all the way to the brake bulb in the tail panel. You hardly see it at all. I gently spliced it into the brake bulb wires. It's just temp rigged in the photo, so you can see the wire still.http://www.logisyscomputer.com/products.asp?PID=STRIP&DID=LEDthey don't show the 12" strip but here is the link I figures out by part number: http://www.logisyscomputer.com/viewsku.asp?SKUID=LDS12RD&DID=LEDBy the way, you can cut these to length if you get a longer one! They are peel and stick, but I "helped" mine with a spot of crazy glue at each end.or here: http://www.axiontech.com/prdt_link.php?item=94434&PRICECOMPARISONSID=ubhgjkpp Edited March 28, 201212 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-385560 Share on other sites More sharing options...
May 9, 201212 yr comment_389505 Tamo3, did you get the light installed? Some pictures would be nice to see. Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-389505 Share on other sites More sharing options...
May 11, 201212 yr comment_389736 Is there much reflection off of the glass at night when you hit the brake? Bump to the pictures request. Link to comment https://www.classiczcars.com/forums/topic/42760-10-additional-led-break-light/#findComment-389736 Share on other sites More sharing options...
