Interpart louvers install
Burl
Just picked up some Interpart louvers for 1972 240z. They came off of a 1972 with all of the hardware except the key. My questions:
Procedures/suggestions for getting the mounts under the window rubber; advice on finding keys or unlocking the locks; making the dull louver shiny. Any suggestions will be appreciated. Thanks to all!
If I recall, the keys were just a "T" shape.
As far as shiney goes, once the anodized finish is oxidized, not too much you can do but paint or re-plating. You can always try polishing a section on the underside to see if that will work.
I just bought a new louver for my 280Z. Instructions are poor, but they do recomend using some dishwashing soap to ease the tabs under the weatherstripping. I'd go with a semi-gloss or matt black finish for a do-over.
