May 22, 201212 yr comment_390802 out of the 3 i have i got 1 mint 1 and another is split in 2 but i could save it and you cant even see the crack and the other one has a piece missing. will take a pic of the split one if you want. Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-390802 Share on other sites More sharing options...
May 23, 201212 yr Author comment_390888 That would be great, I'm happy to repair and refinish the broken part if it's not warped etc Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-390888 Share on other sites More sharing options...
June 24, 201212 yr Author comment_393911 Work has been incredibly busy so I haven't found much time to do any work on the car recently. Last night I finally found time to complete the tail light rings and breather/fuel caps. Masking them was a pretty fiddly task as there are many small faces and lots of angles. Once the parts were fully masked off Troy hit them with some 3M adhesion promoter to help the paint stick to the chrome surface and then a 2 part black with flat clear. Then I had to use some thinners and cotton tips to remove paint off the top of the fins. Then time for some dinner. Troy's shop is just down the road from one of the best Curry shops I've been to, and they make a great curry pizza too! So finally these parts are complete, they now look brand new again, much nicer than the way they started out. Before - After - Now all I need is some replacement centre caps. I'm not sure if I'll get these from City Auto in Japan or make them yet.... Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-393911 Share on other sites More sharing options...
June 24, 201212 yr comment_393914 super fresh Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-393914 Share on other sites More sharing options...
June 26, 201212 yr Author comment_394098 I dug out this gem tonight. I picked it up from Japan a few years ago as new old stock. It suffered some minor damage in storage, a couple of scuffs on the paint work. We tried using some thinners to clean off the paint scuffs and the original paint wiped straight off. It turns out The original paint is acrylic (duh...) so its a bit of a blessing in disguise, I'd much rather repaint the whole piece in 2 pack and match the over fenders and grill. The thing I'm most pleased about is that having this part will allow us to colour match to factory spec. Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394098 Share on other sites More sharing options...
June 26, 201212 yr comment_394103 This is just freaking nuts. You sir are my new hero. Your attention to detail is epic. And your patience is being rewarded with every single part you assemble. Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394103 Share on other sites More sharing options...
June 27, 201212 yr comment_394153 Very nice build! Great attention to detail.. and these parts you've got hiding. Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394153 Share on other sites More sharing options...
July 5, 201212 yr Author comment_394844 I sent my bumpers away to be straightened and re-chromed a couple of month ago or so. They were in pretty poor shape with a lot of dents and surface rust etc. I used the same place that did my electroplating on the headlights and tail lamps. I picked them up from Vinny's (http://www.vinneys.com.au) yesterday and the results are spectacular. They look better than new, I don't think the chrome finish would have been this good from factory! I'd highly recommend them for any Australians looking for metal work. The turn around time on work is generally very good and the cost per bumper is $300ex tax. When you consider the finish of these bumpers and the work that goes into this I think it's very good value! The next thing I need to do its fit some stainless bolts into the reflectors so I can fix them to the bumpers and then source some replacement chrome plated fixing bolts for the bumpers, I'll try Rare Spares or worst case, Yahoo Japan. I'm also goign to assemble the parkers/reflectors and fix them back into the bumper so I'll take some shots of the finished product Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394844 Share on other sites More sharing options...
July 5, 201212 yr comment_394850 I will be looking at doing my bumpers also. 300 is a very good price id be happy with that!! Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394850 Share on other sites More sharing options...
July 5, 201212 yr Author comment_394851 Yep! You can just send them down and they'll send them back to you. Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394851 Share on other sites More sharing options...
July 5, 201212 yr comment_394855 thats unreal for the price, we had some merc bars done for a resto and they where 900ish each and they didnt look that good Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394855 Share on other sites More sharing options...
July 5, 201212 yr comment_394858 try a hardware shop for the bolts maybe? Link to comment https://www.classiczcars.com/forums/topic/42788-1975-c110-khgc110-240k-build/?&page=4#findComment-394858 Share on other sites More sharing options...
