Por- 15 amount
siteunseen
Are you asking about painting the outside of the tank, or using POR-15's product to seal the inside of the tank?
A pint will cover the outside of the tank... just make sure you spray whatever top coat {paint} you plan to use - on - while the POR-15 is still tacky..
Use their Gas Tank Sealer for the INSIDE of the tank, and the regular POR for the outside.
However, in BOTH instances make sure you use their Marine Clean AND the Metal Prep solutions.
Those that have followed the instructions to the letter have had exceptional results, those that have "improvised" have had problems.
You decide.
E
  • Who's Online   2 Members, 0 Anonymous, 646 Guests (See full list)
