OK I rebuilt the front end of my 78 280z and all went great but after a week or so had a bad nose in the front end when backing up. So look under the car and one of the front tension rod was loose and lost the nut and washers. My bad for not tying the nut up. Any one got one off a parts car?:ermm:
When you do get your replacement parts, be sure to check if you should be double-nutting. That is the stock setup on my car because it is virtually impossible to lock up a single nut when compressing rubber or even poly bushings.
Jim
