Posted March 31, 201213 yr comment_385851 Hello ,,,The P.O. removed the glove box to replace the blower. never installed a new glovebox..I took a quick look and cant see how this fits in...Is there any special thing i need to do....it does not go in from the front and cant seem to fit from the rear...this is just that cardboard box...Any tips? THANKS Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/ Share on other sites More sharing options...
March 31, 201213 yr comment_385857 It depends upon what year Z you are talking about. Edit your signature and add your car to it. That will result in better & more timely responses. Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385857 Share on other sites More sharing options...
March 31, 201213 yr comment_385858 Fold or collapse it . Put it in from the front. Take off door. Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385858 Share on other sites More sharing options...
March 31, 201213 yr comment_385861 If it is a plastic glove box, you still take off the front door, but I wouldn't advise folding it or collapsing it. Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385861 Share on other sites More sharing options...
March 31, 201213 yr comment_385862 That is how is is done plastic or paper."You actually have to squish it to get it " http://www.classiczcars.com/forums/showthread.php?25228-How-do-you-remove-the-!!-Glove-Box Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385862 Share on other sites More sharing options...
March 31, 201213 yr Author comment_385905 A 71,,looks like card board Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385905 Share on other sites More sharing options...
March 31, 201213 yr comment_385911 If it is the original glove box, you may be able to fold it and get it into position from the front. If it is a new box, it will probably be very stiff and may not fold easily (potential damage here!). If new and rigid, the install will be best from the rear. The blower motor will have to come out to provide access room. Been there, done that!Jim Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385911 Share on other sites More sharing options...
April 1, 201213 yr Author comment_385938 Thanks Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-385938 Share on other sites More sharing options...
April 2, 201213 yr comment_386053 I recommend to install it from rear, you need to remove the defroster tube and blower motor. Its not the easiest way but most likely best for the glove box. Link to comment https://www.classiczcars.com/forums/topic/42802-glove-box/#findComment-386053 Share on other sites More sharing options...
