grantf Posted March 31, 2012 Share #1 Posted March 31, 2012 (edited) Started work on my rear brakes today. The right side was completely soaked with brake fluid, this explains the fluid loss from the MC. It looks like what happened was the brake adjuster came free from the rear pad or was not installed properly in the past, this explains why my parking brake never worked right. So the adjuster is basically toast from rubbing against the wheel hub and part of it cut into the cylinder seal I need a new one. Actually just the fork end the rest of the adjuster is in good shape. Anyone know where I can find one? not even courtesy parts have it. :disappoin Edited March 31, 2012 by grantf Link to comment Share on other sites More sharing options...
Zed Head Posted March 31, 2012 Share #2 Posted March 31, 2012 There appears to be a 77 280Z at the Arlington Pick n Pull. Link to comment Share on other sites More sharing options...
grantf Posted April 1, 2012 Author Share #3 Posted April 1, 2012 Yippy!!!! now I can find the time, drive up to Arlington and try to get another brake drum off!!! :tapemouthSorry just venting........... Thanks for the tip. It just kills me when some parts are so hard to get.It looks like Z car source has them used for $$$ I have never delt with them before. Link to comment Share on other sites More sharing options...
Zed Head Posted April 1, 2012 Share #4 Posted April 1, 2012 Did you try Zspecialties? He's in your neighborhood. Might not be on the web site but he might have one. http://www.zspecialties.com/ Link to comment Share on other sites More sharing options...
grantf Posted April 1, 2012 Author Share #5 Posted April 1, 2012 (edited) Yes, I browsed there website, no luck. But I have not called them yet. This may sound a little wishfull but all I need is the fork end of the adjuster, what if I found the correct sized steel tubing mashed the end down and reshaped the fork end. just grasping.edit: or welded the fork end onto the correct size tubing. Edited April 1, 2012 by grantf Link to comment Share on other sites More sharing options...
olzed Posted April 1, 2012 Share #6 Posted April 1, 2012 You need new brake shoes as well. They are contaminated with brake fluid, and will never work as they should. Link to comment Share on other sites More sharing options...
grantf Posted April 1, 2012 Author Share #7 Posted April 1, 2012 You need new brake shoes as well. They are contaminated with brake fluid, and will never work as they should.got new shoes, cylinders, springs and pins, cleaned all surfaces greased bosses and other contact points, drum checked out and abraded. Just need the adjuster. Link to comment Share on other sites More sharing options...
ZCurves Posted April 3, 2012 Share #8 Posted April 3, 2012 got new shoes, cylinders, springs and pins, cleaned all surfaces greased bosses and other contact points, drum checked out and abraded. Just need the adjuster.I will look in my parts hoard on Saturday. Sorry, I just cannot get there until then. Link to comment Share on other sites More sharing options...
grantf Posted April 3, 2012 Author Share #9 Posted April 3, 2012 I will look in my parts hoard on Saturday. Sorry, I just cannot get there until then.Cool let me know what you find. I may fab one up but the original would be more desirable. If you do have the fork let me know what I could pay you or trade. I have some odds and ends lying around for 77/78. Link to comment Share on other sites More sharing options...
