hello, this is my first post here, as i just bought my 1974 260z!
i looked on this forum and others for an answer to this and have decided to join this forum as it seems to be a bit more mature than some others.
anyway.... i'm not new to cars, but am new to this Z, so i figure i would ask before diving buying parts.
symptoms;
1 car revs to about 3k rpm when not moving and brake pedal is depressed.
2 no power brakes(barely stops)
if this was a car i was more familiar with, i would guess compromised diaphragm in brake booster.
thoughts?
thanks in advance
-the wombat
https://www.classiczcars.com/forums/topic/42845-my-new-car-doesnt-stop/
A brake booster is a brake booster, doesn't matter what make. A hole in the diaphragm is a good guess. Do some searching on here on the vacuum booster and reaction disk, you will find the answer.
I've seen that happen when someone put the one way vaccum check valve in-line - backward. I've seen that happen when 38+ year old vaccum hoses cracked lengthwise. Just make sure you have good vaccum supplied to the booster first.
Does the car have a new looking Brake Master Cylinder by chance? Inproperly installed/adjusted - the push rod can stop short of applying full pressure as well.
FWIW,
Carl B.
