my new car doesnt stop....
Dr. Wombat
hello, this is my first post here, as i just bought my 1974 260z!
i looked on this forum and others for an answer to this and have decided to join this forum as it seems to be a bit more mature than some others.
anyway.... i'm not new to cars, but am new to this Z, so i figure i would ask before diving buying parts.
symptoms;
1 car revs to about 3k rpm when not moving and brake pedal is depressed.
2 no power brakes(barely stops)
if this was a car i was more familiar with, i would guess compromised diaphragm in brake booster.
thoughts?
thanks in advance
-the wombat
I've seen that happen when someone put the one way vaccum check valve in-line - backward. I've seen that happen when 38+ year old vaccum hoses cracked lengthwise. Just make sure you have good vaccum supplied to the booster first.
Does the car have a new looking Brake Master Cylinder by chance? Inproperly installed/adjusted - the push rod can stop short of applying full pressure as well.
FWIW,
Carl B.
