My '72 is missing an engine-driven cooling fan and clutch, and I scored one from another owner; however, the hub appears to be seized.
Correct me if I'm wrong, but at ambient temperature, I should be able to turn the water pump pulley mounting flange by hand, yes? And there should be molasses-like resistance in the clutch itself?
https://www.classiczcars.com/forums/topic/42851-dead-fan-clutch/
