I have insalled a 3 wire tach into a 71 240Z, stock L24 with 280ZX ignition and distributor and MSD Blaster 2 Coil. I spliced into the original 4 wire tach harness for positive and ground, and ran a wire with a 2200 ohm resistor in line from the negative terminal on the coil to the tach.
When I start the engine, the tach indicates what seems to be the correct idle speed for 3 or 4 seconds, then drops to zero. Revving the engine gets a reading, but my seat of the pants fell is that the reading is too high (indicates about 2800 rpm at 60 with stock 4 speed and 3.36 axle). Also, whenever any electrical load is turned on, such as turn signal, 4 way flasher, or blower motor, the tach needle bounces to a higher RPM and drops back to whatever it read before applying the electrical load.
Bad tach or is something else needed in the installation?
All thoughts wil be appreciated!
https://www.classiczcars.com/forums/topic/42858-tach-problem/
I had a similar problem with a Z31 coil. Installed a typical automotive capacitor/condenser on the negative side of the coil and fixed it. If you're sure the three wires you connected are right for a 280Z tach operation (and they appear to be since you're getting RPM readings), it might just be electrical noise, which the capacitor will quench.
If you have a voltmeter that reads DC frequency (DC Hz), you can measure the frequency from coil to ground and do the math to check accuracy.
Posting here in case a moderator decides to just move the thread.
Frank you are not quite correct. The car has a 280ZX breakerless electronic ignition, which uses a 3 wire tach. Got the problem resolved by cleaning the back of the ignition module and the distributor body where the module mounts. The completed a good ground and the tach works fine now.
Zed Head, see above for what fixed my problem. I also posted the question in the right forum once I realized my error in posting here.
Thanks to both for your thoughts!
Recently Browsing 0
