Posted April 6, 201213 yr comment_386523 I've been doing my research on valve adjusting. I understand it is a simple procedure. However, how do I tell the intake and exhaust valves apart? Thanks! Link to comment https://www.classiczcars.com/forums/topic/42870-intake-and-exhaust-valves/ Share on other sites More sharing options...
April 6, 201213 yr comment_386525 Each valve lines up with the appropriate port on the head. So just look across the head at the intake and exhaust header and you'll see which valve is which. Link to comment https://www.classiczcars.com/forums/topic/42870-intake-and-exhaust-valves/#findComment-386525 Share on other sites More sharing options...
April 6, 201213 yr comment_386529 Valve adjustmenthttp://www.picturetrail.com/sfx/album/view/1803105Valve referencehttp://www.atlanticz.ca/zclub/techtips/valveadjust/index.htmlMechanical valve timinghttp://www.atlanticz.ca/zclub/techtips/timing/mechtime.html Link to comment https://www.classiczcars.com/forums/topic/42870-intake-and-exhaust-valves/#findComment-386529 Share on other sites More sharing options...
April 6, 201213 yr Author comment_386537 Thank you. Those links are quite helpful Link to comment https://www.classiczcars.com/forums/topic/42870-intake-and-exhaust-valves/#findComment-386537 Share on other sites More sharing options...
