Posted April 7, 201213 yr comment_386589 I just finished painting my engine compartment. I am ready to re-install componets and I have all new rubber grommets for the firewall.My question is; the heater hose grommets are bellowed on one side. Does that bellowed section go out, toward the engine compartment, or does it go inward, toward the interior of the car?Any help would be appreciated,DT Link to comment https://www.classiczcars.com/forums/topic/42879-heater-hose-grommet-direction/ Share on other sites More sharing options...
April 7, 201213 yr comment_386594 They go out, towards the engine compartment. Link to comment https://www.classiczcars.com/forums/topic/42879-heater-hose-grommet-direction/#findComment-386594 Share on other sites More sharing options...
April 8, 201213 yr comment_386644 Where did you get the grommets you needed? I live between Gadsden and Anniston and will be getting to the engine bay this summer hopefully. If you are ever in the neighborhood give me a call and stop by. Link to comment https://www.classiczcars.com/forums/topic/42879-heater-hose-grommet-direction/#findComment-386644 Share on other sites More sharing options...
April 8, 201213 yr Author comment_386645 Where did you get the grommets you needed? I live between Gadsden and Anniston and will be getting to the engine bay this summer hopefully. If you are ever in the neighborhood give me a call and stop by.Hey,...I got them from The Z-Connection, (on eBay). They are very cheap.. I assume your avitar picture is your car. My Z is white too. Link to comment https://www.classiczcars.com/forums/topic/42879-heater-hose-grommet-direction/#findComment-386645 Share on other sites More sharing options...
April 9, 201213 yr comment_386685 Thanks, my car is white with light blue inrerior. Link to comment https://www.classiczcars.com/forums/topic/42879-heater-hose-grommet-direction/#findComment-386685 Share on other sites More sharing options...
July 13, 201212 yr comment_395609 Rubber grommets are used to cover sharp edges of a pierced metal sheet. To create a perfect pierce for a grommet, there is also a tool being used for metal eyelets called eyelet setting tool.__________________Have a look at grommets rubber | rubber grommets . Link to comment https://www.classiczcars.com/forums/topic/42879-heater-hose-grommet-direction/#findComment-395609 Share on other sites More sharing options...
