April 10, 201212 yr comment_386813 at the rate he's going i think he'll be ahead of schedule. Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386813 Share on other sites More sharing options...
April 10, 201212 yr comment_386824 Cool thing on the new floors/rockers. Rust and floor jack contact damage in there. Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386824 Share on other sites More sharing options...
April 11, 201212 yr comment_386832 I'm 6-1/2 years in. Every time I get close I find more things to do to mine. Debating whether to restore my york ac unit or leave it off and keep the engine compartment looking clean. This one you found looks pretty good. Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386832 Share on other sites More sharing options...
April 11, 201212 yr comment_386836 Great progress, are you going to media blast or use a chemical stripper to remove the paint? Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386836 Share on other sites More sharing options...
April 11, 201212 yr comment_386838 Wow, great find. Thanks for posting the pics of this series1 s30's interior metal work. Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386838 Share on other sites More sharing options...
April 11, 201212 yr comment_386843 When you're fitting the new floors and frame rails, bolt the transmission cross member and fit the sway bar to make sure you have good alignment on the new metal. Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386843 Share on other sites More sharing options...
April 11, 201212 yr Author comment_386847 When you're fitting the new floors and frame rails, bolt the transmission cross member and fit the sway bar to make sure you have good alignment on the new metal.Will do, I am using some parts such as transmission cross member from my 72 240z parts car. I do have a few questions as this is my first early 70 240z. besides the early models not having any jack compartments behind the seats and the vents in the hatchback, is there any other major differences between 70 and 72? The dash in the 70 is cracked so I plan to use the one from the 72 and swap over the serial numbers, is there any changes in the dash? is wiring all the same? I will be doing some chemical paint remover, some blasting in rust areas and torch fire scrapper on the stubborn rubber coating. Fun fun fun.And yes, I do think I can do this in under 2 months. Will post pics of what I do today later on tonight. cheersjay Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386847 Share on other sites More sharing options...
April 11, 201212 yr comment_386848 Yes, there is a difference between a '70 dash and a '72 dash. No, the wiring is not the same. Early cars had many distinguishable differences. And then there is the issue of the dated parts. Here's some reading for you:http://www.classiczcars.com/forums/showthread.php?31337-Kanji-found-when-removing-a-dash&highlight=kanji+markingshttp://www.classiczcars.com/forums/showthread.php?16870-Discover-various-quot-date-quot-use-cross-reference-method&highlight=date+stamp+kanjihttp://www.classiczcars.com/forums/showthread.php?32826-Well-I-wound-up-with-another-low-VIN-Z&highlight=date+stamp+kanji Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386848 Share on other sites More sharing options...
April 11, 201212 yr Author comment_386849 Also, is there a way to track my 240z history and is there any list of low vin z cars? how many 240z's were made? Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386849 Share on other sites More sharing options...
April 11, 201212 yr Author comment_386850 ok will read up, maybe I will use the cracked dash then, Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386850 Share on other sites More sharing options...
April 11, 201212 yr Author comment_386852 ok will read up, maybe I will use the cracked dash then, Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386852 Share on other sites More sharing options...
April 11, 201212 yr Author comment_386853 Here are my Vin tags of the 2 cars, one is 1970 and the other I think is 72. Link to comment https://www.classiczcars.com/forums/topic/42890-low-vin-240z-is-this-a-good-thing/?&page=2#findComment-386853 Share on other sites More sharing options...
